Sell or part out 1990 535i 5-spd
Fellas,
I'm at a crossroads, my '90 535i which still runs needs to go.
It needs a lot of maintenance, but I don't have the time or ambition anymore (purchased a house). The biggest problem is that it's become an upscale mouse house. They've shredded the hoodliner and have likely built nests in various places (I removed one from behind the driver's knee bolster this weekend, and have removed dead mice from the HVAC blower wheel in the past).
It's been parked under an oak tree for close to a year, and is covered in 'tree dirt' that should clean up. Has little rust, worst of it is around the license plate lamps, very light at the bottom of the doors. Door panel inserts are coming loose as per usual on thses cars. I started to repair one but it still needs completed. Car now has ~250k miles on it.
History on the car:
Bought some 7+ years ago from my brother who spun it into a Jersey Barrier in the snow. Had the frame pulled, and new sheet metal hung on front (bumper cover, grille, hood, fender, etc...) New A/C condenser and evap core (ebay), all new A/C lines from the dealer, and a new compressor from BMA parts; A/C worked for a summer and developed a large leak. Drove for a few years then found a donor 735i 5-spd in the local yard. Swapped in 5-spd trans, new driveshaft from Portland, OR, Bilstein HDs, front suspension arms and tie-rods. New heater core, radiator, water pump, fan clutch, and 2.5" stainless single exhaust made with mandrel bends and chewing gum welds. Also purchased a parts engine w/harness and ECU from the same car, it has a blown head gasket between cyls 2&3 or 4&5, has been stored indoors. Purchased some heated front seats from a different 7-series in the yard to replace the ones in my 535i, but never got around to it, also have a good used steering wheel and clock-spring (one on car has a hole worn in the leather).
Now to where I'm at now: Bought a house 3 years ago which has taken all of my time and money (well most of it). The 5'er got neglected. The front suspension is worn out again (tie rods, idler arm, etc). I've purchased some of the parts (lower control arms, tie-rods, idler arm, sway bar end-links). None of these parts are installed. Tires are worn out on the style 5's, I also have a set of M5 turbines with the wheel covers removed, tires are worn out on those as well... I picked up a cheaper, more fuel-efficient car, and the 5'er got parked. In the time since the car got parked, the mouse damage happened. I'm now to the point that I don't want to screw with it any more and want it gone, whether it's in pieces or whole.
So, what would you do, I'm fairly proficient at parting cars out, but don't really want to spend the time doing it. What's one of these worth (either whole or in pieces)?
Pictures:
When Purchased:
Current:
-Ben
Reason: Spelling
'90 535i - Converted to 5spd
'92 F250 diesel, 5spd, 350k miles, ext cab, long bed, 4wd, bitch to turn (and park) - new tow rig
'96 F250 - dead trans
'95 Nissan 240SX - Infiniti V8 swap in prog.
