ha ha, thanks....
as the window goes up or down it's REAL hard to put a nut on something....
See.. the original bushing/washer thing I posted has a metal shaft that goes through it which is riveted to an arm.
Meanwhile the rolling part of the bushing rolls in a track that's screwed to the door.
Well, once the axle of that bushing is IN the bushing... and the bushing is IN the track... if you put a nut on the thing it just spins, 'cause you can't hold the shaft still to screw the nut on; so you need some way to keep the ARM from popping off the end of the axle shaft.
Enter the PIN in the left picture above.. and you insert the RING (aka RING DING) (the curcular key ring thing) from the picture on the right.
Easy on, easy off.... if you sail a Hobie Cat you have billions of these things around, they more or less hold the boat together.
some of our boats are in the background... on the beach in the island on the right... if you can see it:
http://www.thebeachcats.com/files/ms...island-300.jpg
or this one: http://sailinglouisiana.com/wp-conte..._4405790_n.jpg
or our route: http://sailinglouisiana.com/wp-conte...10/04/trip.JPG
BMW gets all the love in winter... summer, I'm sailing.
Tomorrow is the new headliner install! Will let ya'll know how it goes.
-Rob
