Results 1 to 3 of 3
Thread: 535 vs M5 clutch master cylinder
    Default 535 vs M5 clutch master cylinder
    Can I interchangeably use either of these master cylinders on my 92 535iM?
    535i part# 21521155425, D=19,05MM
    M5 part# 21522226477, D=19,05MM
    They have the same bore size so what is the difference?
    Is there more travel on the M5 one for the bigger bore on the M5 slave?
    It seems the pedal should make either travel the same if it the attachment arm length does not change.
    Also, is the master cylinder push rod supposed to feel like it disconnected internally at the other end when I have the master out of the car?
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    I have checked in the dealer catalog (not the online version on the net), Both have D=19.05mm. Both numbers are valid and there is no mention of interchangability.
    FCP Groton sells the Febi cheap,
    21521155425
    BMW Clutch Master Cylinder - Febi Bilstein 21521155425 | FCP Euro
    Part number: 21 52 2 226 477
    Supplement D=19,05MM Important! Limited storage life. Please Observe expiry date on parts label. Exception: Painting material, see Painting manual "BMW Group Original Color System"
    Usage
    5' E34:
    M5 (S38)
    M5 3.6 (S38)
    M5 3.8 (S38)
    Here cheap for $109, dealer price 160 BMW Clutch Master Cylinder 21522226477 - RM European Auto Parts
    21521155425
    Usage
    5' E34:
    M5 (S38)
    M5 3.6 (S38)
    M5 3.8 (S38)
  1. Need some help with Clutch Master Cylinder
    By bfons in forum 5 Series BMW
    Last Post: 09-03-2009, 12:06 PM
  2. Clutch Master Cylinder
    By GoldenEagleFan in forum 5 Series BMW
    Last Post: 03-18-2008, 03:41 PM
  3. Clutch Master Cylinder Replacement.
    By boardburton in forum 5 Series BMW
    Last Post: 11-30-2006, 04:33 PM
  4. clutch master cylinder removal??
    By peks in forum 5 Series BMW
    Last Post: 06-18-2004, 11:54 AM
  5. FS: e34 Clutch Master Cylinder
    By Sardaukar in forum 5 Series BMW
    Last Post: 03-16-2004, 05:46 PM
Tags for this Thread
