There are heater door motors that control door flaps to direct cool and warm air. Perhaps a motor has failed or a flap is broken. Possibley one of the heater cables that directly connects to a flap is broken. Just gueesing her.
Heat from front window defroster vent and always on with blower as well as when ac is on. Changed heater control valve. Still have same issue. Any ideas on what I could try next?
I have used that vent setting and heat is on. It does get hotter when adjusting heat setting with blower.
Only thing I can think of is to bypass heater core with the hoses. I have 95 530i. Thanks for any help.
I will look at this. Thank you.
read this thread and you know what to check/do
http://www.bimmernut.com/forum/5-ser...nger-side.html
