Results 1 to 3 of 3
Thread: Over heating???
    May 2012
    Default Over heating???
    My 1995 525i over heated on me on the way home from work. My question is, one the fire wall on the drivers side right next to the fuse box there is a thing that has four round things on top of it. There was steam coming from underneath it. What is it? I seen hoses down there but couldn't see anything leaking from them.
    Oldham, England
    If you got steam you may have lost all the coolant. Not good. I'd suggest what you are looking at is the heater valves and under that is the aux water pump:
    Water valve/Water hose BMW 5' E34, 525i (M50)
    yep, heater valves and aux water pump, and I assume the neck of the aux water pump broke and then you run really short on coolant.
    go to my website
    Shogun's Repair Guides for BMW Seven Series
    on the left click fixes and there must be under climate control heater valve repair/ fixing, at least you can see how to remove them and clean them
  1. Car not heating up enough
    By CrimsonBrian in forum 5 Series BMW
    Last Post: 02-21-2011, 06:13 PM
  2. heating problem
    By wappy in forum 5 Series BMW
    Last Post: 11-23-2006, 03:40 PM
  3. 540 v8 over heating
    By dbou in forum 5 Series BMW
    Last Post: 08-25-2006, 08:42 AM
  4. Heating a garage
    By wengenstein in forum 5 Series BMW
    Last Post: 01-07-2006, 12:51 AM
  5. Heating Problem
    By rommel in forum 7 Series BMW
    Last Post: 07-31-2005, 01:35 PM
