The bentley book says, my 89 535i, crankshaft position sensor cable should be secured with tie wraps. When I changed the lower radiator hose, there were no ties, but now I'm not sure how it should be routed. My cable goes down the intake, across then it goes down between the radiator hose and timing cover. Is this correct? I not sure where they want the tie wraps to go.
89 535I
89 volvo 240
78 Pontiac Trans Am, 6.6
I have never seen nor installed tie wraps on the 535i, the 525i M20 YES, but not the 535i.
There isn't much choice when it comes down to routing the cable, it is fairly short. But what you have done seems good.
