Results 1 to 2 of 2
Thread: clutch master cylinder removal??
    Minneapolis, MN
    Default clutch master cylinder removal??
    anything special to removing the clutch master cylinder? how do you get at the feeder tube on the engine side? bentley says to remove that first.. but i cant see it from any angle, let alone get at it(behind the brake master) can you pull it through to the inside of the car and then remove it?
    thanks in advance.
    Albuquerque, NM
    Default Re: clutch master cyl . . .
    Yes, just pull it back thru the firewall & work on it from the inside. You may have to straighten out some of the bends to get it to pull in far enough. If worse comes to worse, you can get a short length of older VW Beetle brake line for a few dollars to replace it with if you want to bend one up yourself. I had no trouble doing mine from the inside.
    gale
  1. Need some help with Clutch Master Cylinder
    By bfons in forum 5 Series BMW
    Last Post: 09-03-2009, 12:06 PM
  2. Clutch Master Cylinder
    By GoldenEagleFan in forum 5 Series BMW
    Last Post: 03-18-2008, 03:41 PM
  3. Clutch Master Cylinder Replacement.
    By boardburton in forum 5 Series BMW
    Last Post: 11-30-2006, 04:33 PM
  4. Replies: 0
    Last Post: 10-10-2004, 11:05 PM
  5. FS: e34 Clutch Master Cylinder
    By Sardaukar in forum 5 Series BMW
    Last Post: 03-16-2004, 05:46 PM
