anything special to removing the clutch master cylinder? how do you get at the feeder tube on the engine side? bentley says to remove that first.. but i cant see it from any angle, let alone get at it(behind the brake master) can you pull it through to the inside of the car and then remove it?
thanks in advance.
Yes, just pull it back thru the firewall & work on it from the inside. You may have to straighten out some of the bends to get it to pull in far enough. If worse comes to worse, you can get a short length of older VW Beetle brake line for a few dollars to replace it with if you want to bend one up yourself. I had no trouble doing mine from the inside.
gale
