Yep.... no castor or chamber adjustment... only toe. A smart alignment guy would know how to compensate for the drifting... just adjust the toe more to stop it. Sometime their machine is off so the alignment is not proper.
Be sure your tire pressure is all the same. One or two PSI difference is enough to make car drift to one side. So be absolutely sure your tire pressure on all 4 tires is spot on.
