Thread: A4S 310R Auto Transmission - No Reverse -
    Default A4S 310R Auto Transmission - No Reverse -
    BMW A4S 310R = GM 4L30E
    A cure for no reverse
    If your car has suddenly lost it's reverse, it could be your Tcc soleniod, when this solenoid goes out your locked out of reverse. A replacement may be purchased at, Transmissionpartsusa under its GM name 4L30E, BMW calls it module A4S 310R this may work for other transmissions too. The part is called a Torque converter lockup solenoid for 1990-1999, Part number 81396A. there is another for 2000-on. you'll see it listed when you go online. the BMW number is 24331218916. I hope this saves some of you the cost of a transmission replacement. The other reason they go out is the clip scears off in the reverse drum and cracks it.
    Transmission parts USA Automatic transmission parts
    details to measure, Ohm etc on the valves
    http://www.kneb.net/bmw/E46/Auto%20t...ion%20info.pdf
    if that link does not work, use this one with the wayback machine https://web.archive.org/web/20131008...ion%20info.pdf
    Revised ATF service (drain and fill capacity) for the A4S 310R and the A5S 310Z
    https://wiki.bentleypublishers.com/d...+transmissions
    Lexington, Kentucky
    Great information. Thanks!
    GENERAL MOTORS® Hydra-Matic 4L30-E automatic transmission Assembly manual by Hans Verhoeven http://scottj.info/files/isuzu/4l30e.pdf
    Lexington, Kentucky
    Wow. It's been a while. In 2012 replaced my failed trany with a remanufactured one from a specialist in CA, I live in KY. In my installed by an independent BMW shop. Been only 24,000 miles. However, i did change the fluid this year. 240,000 on the 95 525i and still going strong.
  1. Replies: 16
    Last Post: 12-26-2006, 09:47 PM
  2. Reverse Light Sw location E34 (Auto Trans) ('95 525i Wagon)
    By HumanRoughDraft in forum 5 Series BMW
    Last Post: 11-05-2005, 10:02 PM
  3. auto transmission mis-shift
    By sgeorge in forum 5 Series BMW
    Last Post: 11-04-2005, 05:50 PM
  4. 525 automatic A4S 310R transmission poll
    By billb in forum 5 Series BMW
    Last Post: 08-30-2005, 10:02 AM
  5. Auto Transmission getting hot
    Last Post: 06-16-2004, 10:41 AM
