Originally Posted by
billb
I'm going to upgrade to a short shifter (Z4 3.0). Here's the list of parts I've got on my order list...anything missing? The numbers refer to position on the screenshot in the ETK, where available. My ETK doesn't have the Z4, so I'm depending on someone else's numbers...
#2 (25 11 1 220 832, Delrin, from UUC), which includes #3 ( 25 11 1 221 849) bitchclip
#4, shifting arm bearing (25 11 1 220 707)
#7, shift lever bearing (25 11 1 220 600)
#12, spacer ring (25 11 1 220 439), 4 qty.
#13, circlip (25 11 1 220 379), 2 qty.
#14, shift selector joint (forgot the part number, and didn't print it off on my ETK screen...)
#18, dowel pin (23 41 1 466 134)
#19, sleeve (25 11 1 203 682)
#20, foam washer (25 11 1 434 194)
Z4 3.0 shift lever (25 11 7 516 160)
31 33 1 092 887 nut (saw this on another site associated with using the Z4 lever)
Anything look like it's missing? I'll also be doing the guibo and center support bearing, so it will be easy to get to everything (I hope). Would you do tranny mounts at the same time? Also doing clutch and brake lines. Can you tell I'm trying to get ready for driving school? ATE Powerdiscs and Hawk HPS are on my upgrade list for next month...
Bill B.
