Originally Posted by
Russell
Upcoming auto trany failure at 207,000 miles
Looks like it has finally happened to me even after fluid and filter changes every 35,000 miles and driving like an adult.
Really starting to slip when shifting gears in Economy mode. Less so in sport mode. Was only doing it to 3rd. Also I often get a slipping sensation then a fairly hard shift. No trans code error. Just slipping shifts when under moderate acceleration. Less so when under light acceleration. I also experience an ocassional delayed reverse engagement and some pendulum shifting under light load.
Do not see any leaks and fluid level is fine and was checked a month ago.
None of the trany shops in my area can seem to do any diagnostics without a teardown. None of the BMW indy shops can do diagnostics or rebuild tranys. They install used or rebuilt units. I have not checked the dealer yet for diagnostics.
My dealer wanted $4,900 for a rebuilt unit not including labor. local trany shop rebuilts were about 2 grand with a 12 month warrenty Then there is a rebuilt unit with torque convertor and electronics update from a nationally known euro trany rebuilder for $3,500 with a 30 month warrently to be installed by a local BMW indy shop.
Nope, I do not want to convert to a manual. Guess I will just have a rebuilt trany installed after I confirm the problem. Hate this, but car is in excellent condition.
__________________
My indy did several checks and could not easily find why my car cannot read codes. It is possible it is because I changed out my instrument cluster to repair a failing dot matrix display.
I used a 95 540i cluster (same part # as mine) and switched out the code plug. Everything worked well with no changes in any aspect of the vehicle's operation. I think 95 540i was made in 12/94 while mine is made in 1/95 with ews II security. There may be a possible conflict. Anyway, not going to switch back until the spring(if needed)
Going to deal with trany issue first. He did say that the lack of being able to read codes would have no effect on the impending trany failure.
