Results 1 to 7 of 7
Thread: Need Help - 1 Wiper not working on 535I
    Mar 2008
    NY
    Default Need Help - 1 Wiper not working on 535I
    My daughter has had the car up at school the past few months. All is well except today, the driver side wiper stopped working.
    What can I expect in terms of a repair? I can either send it to a shop now OR hope it does not rain anytime soon and go up there to try and fix it. Of course today, it's been raining snowing cats and dogs up there.
    Cheers,
    Vince
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    2000 Harley Davidson Softail
    2004 Ford Expedition
    The Nut on the wiper arm is probably worked its way loose and the splines have rounded off in the arm....Tighten the nut down really tight and it will force the splines into the arm.
    Jan 2005
    Wellington, New Zealand
    The wiper arm is designed to fail rather than the splines on the motor. If you replace the arm make sure you clean out the splines on the motor too. They often get clogged up with the arms splines.
    I had this happen just the other week and a new arm was just the ticket. Took a while to get the arm off though it was so stuck on !
    Mar 2008
    NY
    Is it easy enough to see the post turning, IE easy enough for my daughter to be able to tell that this is the problem?
    Once we determine this, where can I get a new cheap arm?
    Cheers,
    Vince
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    Jan 2005
    Yep, if they arent stuck on it only takes a second to get the wiper arm off and you can use the tools in the tool kit and once off you can clearly see the wiper motor spindle turning. You can probably see it turning even with the wiper still on now I think about it. Just get a thin knive/edge, to score the spindle and you will see the soft metal coming out of them.
    The only problem I had with my wipers were my drivers side (RHD for me) has an additional screw to give the blade some force onto the screen when driving at speed. I dont know if you'll have that or not, but it shouldnt take more than five mins to get the old one off, confirm its a problem, scrape the crap out, install the new one, tighten the nut and see it goes round when you flick the arm on the steering column.
    I let me 8 year old to do it it was that easy . Made sure there was a towel between him and the paint work first though !!
    above is for E32, I just found E34 info how to replace the wiper linkage system
    http://www.b-rm.de/wischer.pdf
    German language, but the pics will do
  1. Wiper Arm Q
    Last Post: 08-23-2009, 05:26 AM
  2. Touring rear wiper not working correctly, help please
    By jeffnj525it in forum 5 Series BMW
    Last Post: 02-25-2007, 05:44 AM
  3. E34 525TD Touring rear wiper not working
    By mitch2k in forum 5 Series BMW
    Last Post: 04-17-2006, 12:17 AM
  4. Replies: 3
    Last Post: 02-08-2006, 03:55 AM
  5. 535i Drivers side wiper position
    By epj3 in forum 5 Series BMW
    Last Post: 05-01-2005, 12:07 PM
