Results 1 to 3 of 3
Thread: engine oil leak found-I think
    Lexington, Kentucky
    Default engine oil leak found-I think
    It appears to be leaking around the oil filter assembly. This is a M50 TU engine. Again, it could be the vanos oil line or oil pressure switch where they attache to the oil filter assembly.
    Anyone have an idea on how involved it would be to replace the gasket where it mates to the block? Looks time consuming. Did not find this job in my Bentley.
    It is time consuming but its not difficult. You were around here in the past when others have done it.. Bill B. did a write up with photos but its no longer
    in the files must have gotten wiped out when Ed had to redo alot of Bimmer.info. Here's another link with a small amount of info on it
    Lexington, Kentucky
    Thanks Bill. This link was helpful. It let me know I may not do this myself. Even so i am not sure it is not the vanos oil supply line
  1. found my coolant leak
    By 525i winter driver in forum 5 Series BMW
    Last Post: 05-13-2008, 07:42 PM
  2. found the leak in my AC system
    Last Post: 07-03-2007, 10:32 AM
  3. FOUND MY LEAK!!! pls advise....
    Last Post: 07-15-2005, 04:18 PM
  4. I think I found my oil leak
    By granit_silber in forum 5 Series BMW
    Last Post: 02-04-2005, 07:18 PM
  5. My First 535i, Found Stop Leak in Radiator.
    By rot535i in forum 5 Series BMW
    Last Post: 01-10-2005, 08:47 PM
