replaced instrument cluster
The dot matrix on my instrument cluster was failing. For my fix I purchased another working cluster from a 95 540i, switched the code plug from my 95 525i, while removed, I repaced all the bulbs in the new cluster.
I dropped the steering column to gain access to the cluster. Did not deal with removing steering wheel or airbag. I did disconnect the battery for this work.
All seems well. Only issue I have noted and may not be related is my "oil level light" came on just after I changed my oil, Oil level is fine. Light went away though. Also my Peake code reader/reset tool will reset oil and insection lights but will NOT read codes properly it shows a flashing "E" error code. Not sure this is related. However I did mess with the electrical system with several battery connect/disconnects..
