Results 1 to 5 of 5
Thread: Need help removing door handles
    Aug 2005
    Toronto
    Default Need help removing door handles
    Trying to remove the door handle from a front door. How do you remove that "locking collar nut" from around the lock cylinder?
    It's part number 51211928307. How do you remove it? Do I need a special tool? Little help please?
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Australia
    I just use some pointy nose pliers. The tips fit nicely into the slots in the nut. I don't think mine were ever overly tight.
    clean the threads first using penetrating oil. be careful as you can slip and scratch paint. Use masking tape to save your ass on this one. Paint is not easily or cheaply repaired
    Mar 2011
    Appleton, WI
    There is probably a special tool for that, as these are similar to the locking nut for the antenna on my 66 Dodge. I just used a set of needle nose pliers, and made sure I kept adequate and even pressure against the notches while turning. Worked just fine.
    I also used a plain wire coat hanger for the slider inside the door. Just bend a quarter inch on one end into an "L" shape and use as either a hook to pull, or to push against the end of the slider to lock.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    I like the coat hanger idea. I use a ground down allen key (Eg Max 10mm L-bend at the end) works pretty well too.
  1. inner door handles
    By rockin1978TA in forum 5 Series BMW
    Last Post: 09-06-2009, 12:31 AM
  2. LED door handles
    Last Post: 04-20-2009, 05:45 PM
  3. Leather door handles?
    By blackpawn5 in forum 5 Series BMW
    Last Post: 08-05-2008, 01:07 PM
  4. ::.. BMW Motorsport door handles...
    By Qube in forum 5 Series BMW
    Last Post: 09-10-2006, 11:30 PM
  5. Replaced my door handles
    By Mr. BILL in forum 5 Series BMW
    Last Post: 06-07-2006, 10:48 PM
