Results 1 to 4 of 4
Thread: Park brake lever
    Mar 2011
    Appleton, WI
    Default Park brake lever
    Does the tension or adjustment of the parking brake cables effect how the lever works, beyond possibly how far it pulls up?
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    Oldham, England
    It shouldnt affect the lever's action or ratchet but clearly if you tighten the cables too much the brakes are going to bind.
    Mar 2011
    Appleton, WI
    Understood. Was looking at a car the other day for potential purchase. Owner said the parking brake needed adjustment. I tried the brake out and found that it seemed to hold OK. The lever's action seemed normal. The only thing I found that might be an issue is that the release button in the handle seems recessed too far and is tricky to push in. Seems like its more an issue with the button return spring in the handle than an actual parking brake cable adjustment or replacement.
    thanks.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    No that is the handle pulling forward/off. Just push/pull it back on hard and you'll be good to go. The hand brake has no adjustment, though maybe on the shoes there is some. One is supposed to change them every 10 years, or (probably) 10 hand-brake turns, whichever is earliest
    Have never had to do it myself. Sometimes the shoes are just hardened, a 'conditioning' is what the manual suggests the driver do to achieve 'optimum performance'... LOL!
  1. Shift lever fun
    By filip00 in forum 5 Series BMW
    Last Post: 05-27-2009, 01:03 PM
  2. z8 vs z3 1.9 lever
    By Herb in forum 5 Series BMW
    Last Post: 10-12-2007, 02:53 PM
  3. Replies: 0
    Last Post: 12-09-2005, 07:50 AM
  4. need gear lever in nz
    By crunchy in forum 5 Series BMW
    Last Post: 11-16-2005, 04:32 AM
  5. Help - I can't find the park brake adjuster ???
    By allankennedy in forum 5 Series BMW
    Last Post: 04-01-2005, 03:53 PM
