Hi folks -- I had a LF sticky caliper awhile back (the smell gave it away) and since then I've had a slight vibration at 75 mph plus a kind of pulsating noise that sounds a little like a tire out of round. I replaced both front calipers. Tires checked out OK but I noticed the LF wheel was getting slightly warmer than the right -- not hot, just warm -- after my lengthy commute home. I dug out my dial indicator and found I had 0.005 runout on that rotor.
Think that's bad enough to produce my high-speed symptoms? I don't notice any pulsation when braking. I'm tempted to have rotors turned -- they're Balos with 20K miles, mostly highway.
TIA --
