Results 1 to 8 of 8
Thread: Door locks won't work, windows won't work, wipers only work on high speed
    Aug 2004
    Charleston, SC
    Default Door locks won't work, windows won't work, wipers only work on high speed
    All of a sudden today and at the same moment, my door locks won't work with the remote, my windows won't roll up or down and my wipers only work on high speed. Any thoughts?
    Aug 2004
    Charleston, SC
    Thanks for the info. I have a '93 525iT with the battery under the rear seat and the fusible link with the red wire is intact. It appears on the web page that there is a second fusible link. Do you know if this applies to my car?
    Aug 2004
    Charleston, SC
    Checked both links and they show no signs of any type of corrosion. Where should I check next? Thanks again.
    Check again, its a hairline crack in the link, not always easy to see. Temporarily jumper one of the fusible links with a wire and fuse in line.
    Aug 2004
    Charleston, SC
    Jumped both links and no go. Is there anything else that could cause this?
    Make a GM reset!
    I assume you have checked all fuses under rear seat.
    All these functions are controlled by the GM = general module, in charge for central chassis electronics, that GM is located under the rear seat and GM is written on it. GM is the brain and the orders are executed by the RM = relay module next to the GM.
    GM general module function explained
    Here the complete official info:
    This Service Information Bulletin supersedes S.I. 61 01 92 (3460) dated January 1992. It incorporates additional information on the new General Module software for E32/E34 vehicles.
    Please remove and discard S.I. 61 01 92 (3460) dated January 1992 from your S.I. Binder.
    SUBJECT: New General Modules (GM)
    MODELS: 7 Series (E32), 5 Series (E34)
    - Vehicles produced 9/91 and later
    Situation: New general modules have been used in production since September 1991 in all E32 and E34 models. The software has been completely revised (details of these revisions are found in the attachment to this Service Information Bulletin).
    Part numbers have been changed to reflect these revisions, as listed below, as of September 1991.
    Model Part Number
    E32 61 35 8 356 095,
    E34-up to 61 35 8 356 095 9/91 production
    E34-9/91 and later production 61 35 8 355 812
    Note:
    E34 vehicles produced 9/91 and later have different central locking system components from earlier E34 vehicles; therefore, P/N 61 35 8 355 812 is used only in E34 vehicles produced 9/91 and later, P/N 61 35 8 356 095 can be used in E34 vehicles produced prior to 9/91, and in all E32 vehicles. When the general module is connected to the vehicles electrical system, it will recognize (and store in memory) the vehicle configuration, such as:
    - with/without power windows
    - With/without power sunroof
    - with/without wiper contact pressure control
    - with/without headlight washers
    Important Information
    All general modules must be plugged in only after disconnecting the vehicle's battery. If the vehicle's battery is connected when the GM is installed, undefined signal contacts can cause an incorrect vehicle configuration to be stored, resulting in the impairment of one or more of the above-mentioned systems.
    If one or more of the GM functions are impaired in this matter, the GM can be "cleared" by disconnecting the vehicle's battery for at least ten seconds.
    Warranty Status: Information only.
    Attachment to S.I. 61 01 92 (3460)
    GM Function Changes E32/E34 (Beginning with 9/91 Production)
    - Repeat and Time interlock for headlight washers:
    · Time interlock: 3 minutes
    · Headlight washing at fifth windshield washing after time interlock.
    - Intensive washing pump operating time reduced from 3 to 2 seconds
    - Minimum interval for intermittent wiping is programmable down to 2 seconds (previously 3 seconds)
    - Increased wiper contact pressure during windshield washing cycle is now also provided during dry wiping portion of the cycle (previously only during washer pump operation).
    - Previously, the GM would react to opposing signals (eg., an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command, then the opposing command (e.g., locking, followed immediately by unlocking).
    Repeating the first command then results in carrying out that command (e.g., try to lock again, and locking is now carried out).
    This function ("Asynchronous Position") is omitted in the new GM for all E32 models and E34 models prior to 9/91 (P/N 61 35 8 356 095), and remains in the new GM for E34 models after 9/91 (P/N 61 35 8 355 812) only for central locking commands "lock" and "double-lock".
    - After unlocking is performed due to crash sensor activation, the locking command is now reactivated by double-locking with the key from either the driver's or passenger's door.
    - The "one-touch" operation of windows has been expanded to include all four windows in the opening direction. The driver's window still has "one-touch" operation in both opening and closing directions. Interruption of the "one-touch" feature of the driver's window in the closing direction is still accomplished by depressing any window switch (in any direction), or by depressing the sunroof switch in the "tilt" direction (provided the sunroof is not already in the "tilt" position). Interruption of the "one-touch" feature of the sunroof in the closing direction is still accomplished by depressing the sunroof switch (in any direction).
    - The switch-off delay of the interior lights which occurs after entering the vehicle and closing the driver's door has been reduced from 20 seconds to 15 seconds.
  1. Wipers & cruise don't work?
    By Coldaccord in forum 5 Series BMW
    Last Post: 05-04-2008, 03:18 PM
  2. door locks don't work....stuck open
    By motuman in forum 5 Series BMW
    Last Post: 03-18-2005, 10:18 AM
  3. Replies: 7
    Last Post: 12-16-2004, 12:42 PM
  4. Replies: 11
    Last Post: 12-02-2004, 11:56 PM
  5. Dead computer/wipers/radio/door locks/windows
    By misfortune in forum 5 Series BMW
    Last Post: 04-04-2004, 11:36 AM
