Bmw E34 540
Hi all, new to this form and looking for some help please...I have a 1995 E34 540, had the car for under 8months with 146k on the clock, the car was driving very well until last week, all of a sudden the car decided to drive very rough, its rough at idle too. Have checked the maf and air intake hoses and all are ok. I am in 2 minds if its the plugs as the car has not been serviced as yet, just had a oil change since i have owned it.No engine management lights have come on. Its just very rough, any advice will be appreciated as to what i should or check before i get the plugs changed.Another problem is the rear windows, when pressing the down button, i can hear the motor trying to bring the window down but both don't move. The left window at times does decided to slide up and down... All advice will be appreciated and thanks in advance.
Possible intake manifold leak. How do you check your MAF?
For the window... try slamming your door and see if that solves the problem... I think the window is sticking to the seal too hard that the motor could not overcome it.
Hi Tiger, thanks for the advice buddy
The way i was told to check the maf was i disconnected it from the plug, there was slight difference as to when it was plugged in or when it was not, i tried another maf from another 540 from a friends car and done the exact same. When i brought the car and when it had its oil change, the oil was filthy, the car sat for about 5 months as the owner moved abroad and just a one owner car. I did have doubts about the spark plugs as the condition of the old oil did indicate it might need a full service soon with one green service light left !! I am not mechanically educated but learning through this form. As i said, any advice will be great.Funny enough when my son slammed the rear door shut, thats when one window went down ! So i atleast know why that is. How can i soften the seal or is it new ones... Thanks.
How do i check the intake manifold for leaks ??
Got the car checked out later today and it is the plugs so as its time for a change, i have been looking at different plugs and in two minds wether to go for the Bosch or Champion plugs.
I have seen Champion EON 4 plugs and Bosch Platinum 4 plugs, What ones would be recommended and also what does the EON 4 mean as this number goes up to EON 7 in the champion range... As my 540 is V8, does this matter in any way.... The old plugs are Bosch ones in the car. Thanks
Do NOT use +4 plugs... they cause too much problems in BMW. Stick with basic Bosch single electrode copper plugs. No platinum or anything fancy.
Hi Tiger,
I got the plugs changed. I can only say this much that had i even attempted to take a picture of them and shown you them, i would have died of sheer embarresment.
though keeping in mind i have had the car for under a year and only done 400 odd miles, the previous owner had the service done about 3 years ago and covered under 2000 miles in the car, one owner with fsh all mot. Its beyond my understanding how on earth the plugs were in such a bad condition, they were burnt out and the white ceramic part (I think it's ceramic) was cracked in all 8 of them. very poor.
Anyway after this change, the car is purrring like it should and the V8 is running smooth and better
Next thing to sort out is the rear windows, waiting for a good dry day to see to that. As i mentioned the windows dont go down but you can hear the motor clicking whilst trying to pull it down, How do i soften the rubber seal and could it be the inner or outer seal...
I am also breaking my E34 525i Auto, 1995 model, if you need any parts then let me know as i need the car gone by mid july.
Thanks and regards
Hi Palerider.
Where are you and what color is your 525?
Hi, I am in Glasgow, UK...
Sorry, Its a Sorrent Blu 525i, 1995 model.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
