Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: NEED HELP ASAP!!! Any Advice On Plugging the Oil Cooling Lines Back In?
    Oldham, England
    Quote Originally Posted by BMW4LIFE View Post
    WTH....realoem.com not longer has the E34....ARRRGGG
    THIS IS BS!!! >=(
    Erm...yes it does. Click on archive. It is top of the list.
    Anyway, you probably mean this bit and I agree the alignment is probably out. You tried to do it from the bottom?
    http://www.pelicanparts.com/bmw/tech...Lines/pic3.jpg
    Sep 2005
    Central Coast, CA
    yea I was in the bottom of the car (without it being on jacks) and tried to push it in.
    Tomorrow I am going to bleed the brakes so the car will be on jacks. So hopefully I will be able to achieve a better angle (alignment)
    I hope it is as simple as that.
    http://www.bimmernut.com/forum/image.php?type=sigpic&userid=3314&dateline=1239168  877
    Jan 2008
    Sweden
    And some vaseline on those pipes maybe.. Good luck!
    If you loosen the radiator, it will allow the few degree of movement just so you can get the thread started. Radiator is easy to unlock and lock into place.
    Sep 2005
    Central Coast, CA
    I FINALLY DID IT!
    After some thought I decided to do the most obvious thing. I pour out some tranny fluid on my finger and rubbed it on the outside of the hose and the housing and with some wiggle it went in. Ahhh that was super frustrating but thank you all for your help!
    Now it is time to refill the tranny fluid, get some new brake fluid in the car, and change out the rear diff.
    Anyone change out their tranny mounting bushings? Advice? Difficulties?
  1. Garage ****ed my car up BAD... need advice ASAP.
    Last Post: 04-24-2008, 08:00 AM
  2. Anyone know how to replace 530iA trans cooling lines.
    By bimerguycw in forum 5 Series BMW
    Last Post: 03-09-2007, 12:11 AM
  3. Replies: 18
    Last Post: 10-12-2006, 09:40 PM
  4. Okay, now cooling prob is back, what do I do!
    By Rob in forum 5 Series BMW
    Last Post: 05-04-2006, 11:42 PM
  5. Replies: 12
    Last Post: 05-11-2004, 12:50 AM
