Results 1 to 10 of 15
Thread: NEED HELP ASAP!!! Any Advice On Plugging the Oil Cooling Lines Back In?
    Sep 2005
    Central Coast, CA
    Default NEED HELP ASAP!!! Any Advice On Plugging the Oil Cooling Lines Back In?
    Like the title says...
    I took out the radiator out and changed it out (without removing the fan....which was sooo much less work and totally manageable) but I didn't know that I had to pull the tranny cooling lines to remove the radiator.
    I ended up taking them off with minimal loss of tranny fluid but now there is NO WAY in Gods name that they are going in....Any advice?
    The cooling lines are not the ones built into the radiator rather a separate mini radiator attached to the front of the radiator.
    Thanks guys!
    http://www.bimmernut.com/forum/image.php?type=sigpic&userid=3314&dateline=1239168  877
    Not sure about your car... but it seems like alignment problem... so I would loosen up the radiator and try to get it in before you finally place the radiator into position.
    Sep 2005
    Central Coast, CA
    The radiator is already mounted but the cooling hoses are flexible enough that they can be somewhat manipulated. It just seems that they just wont go into their holes for some reason!
    I would appreciate more than one feedback as I need to get this beast back on the road.
    Thanks guys!
    If you loosen the radiator, it will allow the few degree of movement just so you can get the thread started. Radiator is easy to unlock and lock into place.
    Sep 2005
    Central Coast, CA
    I FINALLY DID IT!
    After some thought I decided to do the most obvious thing. I pour out some tranny fluid on my finger and rubbed it on the outside of the hose and the housing and with some wiggle it went in. Ahhh that was super frustrating but thank you all for your help!
    Now it is time to refill the tranny fluid, get some new brake fluid in the car, and change out the rear diff.
    Anyone change out their tranny mounting bushings? Advice? Difficulties?
    check the threads, might be a different size? Never heard of such mishap.
    Sep 2005
    Central Coast, CA
    That is the thing...they are not threaded.
    http://www.turnermotorsport.com/imag...EM_part_sm.jpg
    Sorry for the horrible pic but this is all I could find.
    This thing connects to the front of the radiator. In the bottom left where there are two hole. That is the in and out of the tranny cooling lines. They seem to push ones as they are smooth. But for some reason I am unable to push them in...I am going to try to give it a love tap in the morning but I would appreciate any other ideas.
    p.s. I will look for a better picture
    Sep 2005
    Central Coast, CA
    WTH....realoem.com not longer has the E34....ARRRGGG
    THIS IS BS!!! >=(
    Sep 2005
    Central Coast, CA
    Sep 2005
    Central Coast, CA
  1. Garage ****ed my car up BAD... need advice ASAP.
    Last Post: 04-24-2008, 08:00 AM
  2. Anyone know how to replace 530iA trans cooling lines.
    By bimerguycw in forum 5 Series BMW
    Last Post: 03-09-2007, 12:11 AM
  3. Replies: 18
    Last Post: 10-12-2006, 09:40 PM
  4. Okay, now cooling prob is back, what do I do!
    By Rob in forum 5 Series BMW
    Last Post: 05-04-2006, 11:42 PM
  5. Replies: 12
    Last Post: 05-11-2004, 12:50 AM
