Results 1 to 10 of 16
Thread: New product: Subframe stiffening plates
    Canada, ON
    Default New product: Subframe stiffening plates
    Link to see more details
    Works on any E34/E32 and E32, this product is very easy to install without a lift, it is placed between the subframe mount and its bracket. It will stiffen the rear of your car and remove some bodyroll. Perfect upgrade with or without sway bars.
    FREE SHIPPING. :-)
    Next, I will have to inserts for 750i bushings to make them slighly stiffer and make the car corner even better. Works great even on stock cars.
    See I didn't forget that I have E34s hehehe.
    Lexington, Kentucky
    Default This sounds interesting- some questions
    Will it affect ride by stiffening the rear of the car?
    How do you install? Do you replace a bushing? I do not understand where it goes.
    Does this bushing have the potential to reduce rear steering?
    Please tell us more about the following:
    "Next, I will have to inserts for 750i bushings to make them slighly stiffer and make the car corner even better. Works great even on stock cars"
    I believe you are discussing the front end. Will these inserts fit stock bushings in the upper thrust arms and how do you install them? Will it require the upper thrust arms to be removed?
    Quote Originally Posted by Bruno
    FREE SHIPPING. :-)
    Bruno....do you have a technical explanation of why they increase the solidity of the rear end i.e. how they interact with the bushing to add stiffness/control? The picture is not clear as to how the insert interfaces with the bushing. I presume it has to finger down within the air-space of the bushing to minimize lateral displacement of the bushing. How about some background?
    Also typical of just about any suspension mod, there is no free lunch. Is some ride quality lost?
    George
    Canada, ON
    Quote Originally Posted by George M
    George
    Basically, the way the bushing is designed, there is a big gap between the bushing and the plate. So the bushing is allowed to flex up and down. (this is probably what is killing it) By adding a plate and getting ride of the void, the bushing cannot flex as much and will be tighter. That means the rear end will react way faster.
    My car is so stiff, I cannot tell you if the ride is affected, the car was definitively tail happy after the mod and the sway bars. A couple of customers in Canada have the mod and didn't report any noise increase or other problem.
    They already do that on the 3 series.
    Canada, ON
    Quote Originally Posted by Russell
    Install:
    Remove the plate that is holding the subframe mount: 3 screws.
    Install the large Racing King washer and re-install the plate holding the subframe mount.... Voila. I will take step by step install pics when I will install the next pair.
    As for the thrust arms inserts, they will work on stock and 750i bushings also.
    You just need to remove the bolt holding the bushing, you don't need to remove the complete arm. They make the car more responsive and doesn't make it stiff at all.
    Lexington, Kentucky
    Default Thanks-could not find thrust arm inserts at Raceking?
    Not sure if you said they available yet?
    Install:
    Philippines
    ok, quick question re suspension bushings ... both front and rear... I know you're supposed to tighten the bushing under load... I was just wondering if installation procedure is common for all or at least most German cars... Merc, Opel, etc...? Thanks
    Unregistered Guest
    Default Do you need new sub-bushings?
    Do you need to replace the rear subframe bushings before using this plate?
    I have a 90 535i/5spd/95K and have never changed this bushing. Changing the subframe bushing looks like a pain:
    http://www.bmwe34.net/e34main/mainte...amebushing.htm
    Could this plate be used in lieu of actually changing the subframe bushing?
    Lexington, Kentucky
    bump
    Lexington, Kentucky
    rebump :-)
  1. Anyone seen this product before?
    By Rick L in forum 5 Series BMW
    Last Post: 01-16-2007, 12:01 AM
  2. E34 Subframe Reinforcement Plates - Review
    By Mr Project in forum 5 Series BMW
    Last Post: 11-30-2006, 12:40 PM
  3. Car Care Product Giveaway
    By dternst in forum 5 Series BMW
    Last Post: 07-16-2006, 11:16 PM
  4. hi-res product shot of M3?
    By jplacson in forum 3 Series BMW
    Last Post: 04-01-2006, 05:12 AM
  5. Bruno's subfame stiffening plates torque values
    Last Post: 07-06-2004, 05:48 PM
