Hmmm it appears it maybe a grounding issue.
I didn't actually fit the OBC into the center dash.
I just connected the plug.
There is a metallic strip on top of the OBC that appears to be a ground.
I'll try it again tomorrow!
I'm am attempting to swap the OBC from my E34 535i (Nov 1989) into my 525i Touring (April 1992).
There are two part numbers on the rear of the OBC...
65.81-1389619 - BMW
65 91 11.19.11 - SIEMENS
The Touring is fitted with the digital clock/date/memo/temp unit (not the basic analog clock) and also has the full Check Control instrument cluster display. The 525i's plug and loom appears to have the same compliment of connector wires as the 535i.
Today I removed the OBC from the 535i and connected it to the plug in the 525i Touring but got nothing. No display (not even 'PPP'), lights or anything! It seemed completely dead.
I tried it again back in the 535i just to make certain it was still working and it was fine.
I've yet to fit the indicator stalk with the OBC cycling switch from the 535i (though I believe I may require an airbag compatible version)
QUESTIONS
- Do I also have to fit the 535i's indicator stalk in order for the OBC to work at all?
(I do intend to fit it anyway but I wanted to make sure the OBC was going to function in the 525i first)- Do I need a coding plug?
depending on the options that your 535 had you will either need to fit the obc horn relay under the rear seat(at least thats where it belongs on the sedan) or if your 535 had the dwa alarm you need to fit it instead (both options plug into the same green plugs under the rear seat). It supplies power to the obc on one circuit that the clock/temp unit doesn't need.
I've done the same retrofit to a 94 525 and this was necessary.
Thanks Myles.
Now I have to locate the relay position under the rear seat.
Plenty of discussion about it on the net it seems... but no pictures!
its infront of the general and relay modules and screws onto the inside of the kick panel behind the rear left passengers feet.
Thanks, I eventually managed to find a vague picture of it.
It doesn't look like a standard relay.
It's more like a rectangular module with its' own fuse.
Under the rear seat of my 525i Touring I found a connector with four colour coded wires that matched the colours of the aux horn relay module connector in my Bentley manual circuit diagram. What had me confused was the connector itself didn't match the terminals of a standard relay. The plug had four round female terminals. I assume this plugs into the aux horn relay module?
The catch is finding one of these. Do you know if E32's use the same relay module?
Here's some better pics of the relay module removed
any e34/e32 with an obc and without dwa will have one. any cars with dwa will have a larger module plugged into the same wires.
I picked up an OBC auxiliary horn relay from Peninsula BMW this afternoon.
I now have a working OBC in my 525i Touring!
Thank's for your help Myles.
Until I managed to find an actual photo of the horn relay I was visualising something quite different..
The s/h relay cost me $35.
It was out of an E32.
They initially wanted $75 for one but that's more than a new one so I let him know and he dropped the price.
The next thing to fit is the stalk.
good work.... ready for some weekend driving
