Results 1 to 8 of 8
Thread: E34 tyre wear pattern
    Feb 2005
    Penang, Malaysia
    Default E34 tyre wear pattern
    folks, i mostly drive my car alone ie driver only and have checked my wheel alignment and the local shop says everything checks out against their computer database.
    now my tyre wear patter is like this:
    - both front tyres: more wear on the outer side treads
    - both rear tyre: just slightly more wear on the inner side treads
    is this about normal for a e34?
    btw what is the factory spec for camber, toe in/out & caster for both front & rear wheel?
    Caster is not adjustable and has nothing to do with tire wear.
    Chamber is not adjustable unless you buy adjustable plates.
    Toe In and out does affect the inner and outer wear of tires.
    I suspect in your case is that your springs in the rear are sagging... causing inner tire wear. And because of the rear spring sagging, the front is 'lifted' up causing your outer tire wear. So by replacing your springs, it should solve that problem. If you got 100+K miles, it is time for new springs... not sure about your shocks at this point.
    Wellington,New Zealand
    my car has always worn the tyres like that....I swap from front to back on the same side to even the wear out a little.Do not swap diagonally,otheweise theoutside front becomes the inside rear,and will continue to wear unevenly.Swap them before they get too bad.
    Gone but not forgotten
    Nov 2006
    Mid-Atlantic, USA
    Sounds perfectly normal to me, as long as you're talking about after many thousand miles of wear.
    Feb 2005
    Penang, Malaysia
    folks, so after 3 replies, can i conclude that my wheel alignment is ok and that there is no rear spring sagging etc??
    tire wear seems normal to me.
    What is the mileage on your car? What mileage period are you taling about for tire wear? 1000 miles?10,000 miles? 40,000 miles? How new is yoru tire?
    Like I said, if it is wearing quite fast, then something is wrong.
    Feb 2005
    Penang, Malaysia
    tiger, the current set's mileage probably ~20,000 miles since the last change - did not rotate them.
  1. Front tyre inside wear
    By E34-520iSE in forum 5 Series BMW
    Last Post: 10-19-2006, 05:14 PM
  2. Tyre wear and bad judder from steering wheel
    By shuriken in forum 5 Series BMW
    Last Post: 06-10-2006, 09:21 AM
  3. ET, bolt pattern etc. for all BMW
    Last Post: 10-15-2004, 12:07 AM
  4. Tyre wear question
    By Marshy in forum 5 Series BMW
    Last Post: 03-06-2004, 02:19 PM
  5. mark d or anybody that knows about the ECU learning pattern.....
    Last Post: 02-25-2004, 01:05 PM
Tags for this Thread
