Results 1 to 5 of 5
Thread: Some advice please - suspension woes
    Aug 2008
    London, UK
    Default Some advice please - suspension woes
    Hi,
    I've had my 525 for quite a while now (bought back in 2003) and have now replaced almost all of the suspension, all with OEM or Lemforder parts:
    Jan 2007 - front anti-roll bar links
    Sept 2008 - front ally control arms and front thrust arms (came with bushes already installed)
    July 2009 - outer steering tierod ends/ball joints.
    Oct 2009 - rear beercan bushes (Done by dealer)
    Sep 2010 - rear dog bones
    Oct 2010 - Thrust bushes (750i versions) & tracking done
    As you can see I've replaced the thrust arm bushes twice - once in Sept 2008 and then again last month with 750 (green) ones. Unfortunately I got a garage to do it last month (all other work done by myself), and now a month after they've done it, the car is pretty much undriveable above 40 mph - hit a pothole and it suddenly lurches to the left or right.
    I spoke to the garage and they are adamant that they tightened up the bush with the weight of the car on them (if you don't do this it rips the bush). I'm not 100% sure they did, but can't be sure. Anyway they suggested that 'some thing else' may be killing the bush (so to speak!)
    Any idea's why this bush would have been killed so quickly ? thoughts ? I don't really want to replace the bush again only to have it fail ~ 1 month later, and I'm not really sure what to do.
    sal
    Busted thrust arm bushing would yield up down steering shakes... not car moving left right. Assuming your car will steer straight if you let go your steering wheel on straightway highway... then I'd say your alignment is probably ok.... they always say to do front end alignment after bushing job.
    Assuming alignment is okay, next suspect is your tires.
    Oldham, England
    I hear you got a few snow flakes so maybe not the time to be rolling around on the floor yourself. Why not get an MOT tester to have a look? VOSA would be even better but you might not like what else they find:-)
    m5 thrust bushes last longer and are harder. the work by the shop does it have a warranty?
    Wellington,New Zealand
    I can assure you that if the job is done correctly E34 M5 bushes last for years
    Gone but not forgotten
  1. replacing suspension. Looking for advice
    By infurno in forum 5 Series BMW
    Last Post: 11-01-2008, 07:14 PM
  2. suspension woes
    By RallyD in forum 5 Series BMW
    Last Post: 04-28-2008, 10:01 AM
  3. Front Suspension Advice
    By av8r in forum 5 Series BMW
    Last Post: 01-17-2006, 02:16 PM
  4. ADVICE on New Suspension fitment
    By MotoMan in forum 5 Series BMW
    Last Post: 07-12-2005, 08:50 PM
  5. Help! Suspension advice needed on SACHS sport kit
    By Kalevera in forum 5 Series BMW
    Last Post: 12-08-2004, 02:14 AM
