Originally Posted by
Tiger
That's the injector I bought... Bosch 0280150710 19lb injector with modern 4 hole design. 18MPG is fantastic based on your driving habit...
The fuel injector has the same flow and spec as original. Only difference is the 1 hole and 4 hole type. I'll pick up a few extra orings... just in case.
I am on a quest to see if I can eak out 20 MPG in city.
Just coat the o-rings with a little bit of fresh motor oil before you seat the new injectors. Makes 'em slide right into place w/out harming the o-rings. Much easier to install them like that than trying to do it with the injectors dry.
Not sure if you'll get 20 in the city. You can probably get close though. What software you running? My mileage increased a good bit running EAT software over stock. Stock I was getting 26 highway, EAT w/MAF that was on it's way out I was able to get 29.5
