Results 1 to 10 of 20
Thread: Clunk Clunk Clunk...gets old after a while! =X
    Sep 2005
    Central Coast, CA
    Default Clunk Clunk Clunk...gets old after a while! =X
    So I was out and about and noticed that the front (especially right corner) of my car would clunk over every little bump on the road...and I mean EVERY!
    Unless the road is like glass, I hear this dang clunk all over
    I have changed the from sway bars (which I thought would be the cause) but no relief
    I was thinking maybe something with the struts? like that foam piece that is suppose to go in could corroded?
    Any help?
    Thanks!
    http://www.bimmernut.com/forum/image.php?type=sigpic&userid=3314&dateline=1239168  877
    May 2006
    NH
    The sway bar links should be replaced..
    1995 540i Manual build 1/95
    Sep 2005
    Central Coast, CA
    So as I stated above...
    I have just recently replaced the sway bar link with brand new lemforders
    so that can not be the problem!
    May 2006
    NH
    lol.. sorry I need to get some sleep..
    okay, the balljoints on the upper and lower control arms, are they torn or look intact?
    Apex, NC
    I don't think that foam piece matters. But how about the strut mounts? I don't know about the fronts, but the rears can wear out and become loose.
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Jun 2006
    Wisconsin
    Yes, a bad mount can generate a lot of clunking. You can often feel the strut assembly binding up while cramping the wheels at low, low speed, like maneuvering in a parking lot.
    The cap holding the strut insert in place may have loosened up as well. I don't think a missing bump stop would produce the kind of noise you're describing. Sure does sound like it would be in the strut assembly, though. You're not feeling any shimmy or looseness in the steering, are you?
    Houston, TX
    Did you check the tie rods? If the ball joints are loose, it could give that symptom.
    Need to check the sway bar links. Yes I read that you replaced them but your issue leads right to them. They are pretty hard to check with only 1 person and much easier on a lift. The ball joints will clunk when going very slow and jabbing the brakes but not usually on bumps.
    Edit: Check the swaybar link bolts! I had 2 of them loosen up on me. So hard to get them tight enough on the strut bracket.
    Sep 2005
    Central Coast, CA
    No worries! =)
  1. front end clunk
    By edward in forum 5 Series BMW
    Last Post: 11-12-2007, 05:50 PM
  2. found my clunk
    By Elekta in forum 5 Series BMW
    Last Post: 11-03-2007, 08:44 AM
  3. Front end clunk?
    By emil in forum 5 Series BMW
    Last Post: 09-12-2007, 07:27 PM
  4. clunk from rear
    Last Post: 08-26-2007, 01:12 PM
  5. where's my clunk?
    By bigtallsam in forum 5 Series BMW
    Last Post: 06-15-2006, 08:28 AM
