Originally Posted by
ryan roopnarine
it seems like you're under the impression that simply removing/installing this item will impart radical ramifications onto the operation of your vehicle....that's why i suggested you swap, as if it doesn't work, you just swap back and drive the e34 to the e30 store. the only way its likely to damage something working is if by removing the hose you crack the end from the stresses. my icv hoses/unit has been on/off with no changes in vehicle operation so long as one does not try to start the car. it is prudent, if you feel that way, to leave the 535 alone until you've tried all the other steps, i guess. i have hose clamps on the end of mine for extra sealing, but it doesn't come that way. pull on/off, spray some o2 safe cleaner, rinse, repeat until it isn't gucky any more, and try. removing this component isn't as drastic as, say doing something like removing an intake manifold, IE you don't have to worry about surface sealing affecting operation in that drastic a manner.
