when a boot has been broken for a while, the grease disappears, and you can hear it start knocking, is the balljoint no good then?
That happens when they break, dust, water enters:
http://bmwe32.masscom.net/sean750/ba...JointBoot.html
Talked with the people from car-parts24 in Germany, they now have them online after I gave them the hint where to buy in Denmark
http://www.car-parts24.eu/products/B...33-x-15mm.html
bigger ones for the upper and lower arms 2,69 EUR/piece
http://www.car-parts24.eu/products/B...29-x-14mm.html
smaller ones for tie-rods 2,39 EUR/piece
with the clips. Plus shipping cost
These are better than the ones from BMPDesign,
http://www.bmpdesign.com/category-exec/category_id/56
as they are made of rubber and have the clips, so no grease can disappear
Yep, once it is knocking, it is toast.
the axle boot on my '94 Suburban broke 2yrs ago....it's somewhat sealed against the axle, just pressure fitting in there. IT's still good, i've put about 40k on it since lol.
We often use in our wrenching group the upper arms again by pressing in new Meyle HD thrust arm bushings, because the other side with the ball joint is still o.k., on that part we add such rubber boots new.
BTW, Kris
tie rod ball joints I still have some new ones, in case you need again.
Perfect timing, my left lower arm has begun knocking. Thx Shogun!
I found another source in the U.K.
Slide-a-Boot CV Boot Kits
Medium Slide-a-Boot CV Kits
Large Slide-a-Boot CV Kits
Universal CV Boot Kits
CV Boot Clips & Grease
Universal Balljoint Boots
CV Boot clips fitting tool pliers + 20 ss universal clamps heavy duty
PANDA TOOLS AND PRODUCTS Universal Balljoint Boots, Air Hoses And Fittings items in PANDA TOOLS AND PRODUCTS store on eBay!
Here is their website http://www.cvbootclips.co.uk/
In their offer they have mentioned the sizes from ....to for the smaller and the larger holes for each boot, so easy to select.
following sizes are needed for E32 and E34 as far as I remember
tie rods 29 x 14mm
wishbones/thrust arms 33 x 15mm
Or get a garage pack or a mixed pack, then you have them all.
