Results 1 to 3 of 3
Thread: Loose Driver Door Window
    Houston, TX
    Default Loose Driver Door Window
    This ever happen to anyone? Let down the window on the dirver door and it seems to have come loose. The pane is not broken, and the motor still runs, but the window is loose in the channel - like whatever adhesive that held it gave up. I am assuming that the lift pantograph thing is intact - certainly no noise to indicate that it is broken or askew in any way.
    Haven't had a chance to open up the door panel, but if anyone has experience, I'd appreciate any input.
    If it just got loose and came out of the frame, is silicone okay to re-secure it?
    Thanks.
    Mike
    Albuquerque, NM
    Common problem. There are 2 plastic ball & socket brackets on the bottom rail. One probably broke or popped out. Sometimes the metal retainer clip pops off & you might find it in the bottom of the door. Replacement piece is part number 51 32 1 938 884, $1.89 at AutohausAZ, maybe $3-4 at the dealer.
    gale
    Houston, TX
    Thanks, Gale - took it open this afternoon and found exactly that - both clips were beat up pretty good and seriously gunked up. One was popped out, but both will get replaced.
  1. Driver side front window issue
    By Al Gray in forum 5 Series BMW
    Last Post: 07-15-2006, 10:32 AM
  2. Need help with driver side front window
    Last Post: 04-08-2006, 03:21 PM
  3. Replies: 3
    Last Post: 12-29-2005, 08:57 AM
  4. Wagon Tailgate Window is Loose
    By Shade Tree in forum 5 Series BMW
    Last Post: 11-11-2004, 10:48 AM
  5. driver side window
    By caster in forum 5 Series BMW
    Last Post: 03-28-2004, 09:36 PM
