Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Finally, got the diagnostics working...
    Australia
    Hi Nick, I've got both of those version of ediabas running correctly. Both of my versions have had some files missing, but 643 was much more complete. Have a look at this link for lots of good info for ncsexpert - http://forums.bimmerforums.com/forum....php?t=1483234
    Its a powerful tool and can make a complete brick of the car if used incorrectly. I've used it when I retrofitted things like the OBC, cruise, dwa and park ventilation to my e36 so that everything was coded correctly and did actually work. Before that the OBC was always complaining about the missing check control system and the dwa and park vent wouldn't work at all.
    Yep, that is indeed. I was keen from the moment he mentioned doing it. I bet Fister's still around, just moved on to other things I guess. I reckon he had some trouble shipping them, though luckily mine came through and came with excellent doco. I suspect customer problems probably got too great, and I'd suspect that'd be more to do with people's particular software and hardware installations.
    On second thoughts, I found these in my docs... but can't attach.
    Perhaps you could find them online and see what functions work, and which don't with your cs setup.
    Search for the files;
    Using Carsoft Cable for Dis with INPA.pdf
    Using Carsoft Cable for Dis Protocol and Process Settings.pdf
  1. O2 sensor diagnostics
    Last Post: 10-14-2008, 09:01 AM
  2. E34 535i Diagnostics
    By mattyp in forum 5 Series BMW
    Last Post: 02-28-2008, 11:06 PM
  3. ediabas diagnostics
    By nariusb in forum 5 Series BMW
    Last Post: 11-30-2007, 05:25 PM
  4. BMW On Board Diagnostics
    Last Post: 11-05-2007, 01:39 AM
  5. Odometer finally working again
    By Scott E in forum 5 Series BMW
    Last Post: 04-07-2004, 10:50 PM
