Thread: HID Retrofit
    Mar 2009
    Sydney
    Default HID Retrofit
    Has anyone fitted aftermarket HID lights to their E34? (mines a 1993).
    If so, did you have any problems with the blown globes indicator?
    A few years back I retrofitted to a 2003 C-class Mercedes and it was just a matter of dropping into the local dealer to have the computer changed to know it now had HID's.
    But I doubt thats available on a 1993 E34.
    I don't particularly wish to use the resistor loading trick either if I can avoid it - defeats the lower current pull of the HID's plus they can get quite hot.
    ss2115.
    BMW 525i Touring - 1993 (current drive car).
    DS23 Citroen Safari - 1974 (restoration and modifications).
    Golf MkIII - 1997 (fun car and daughters learn-to-drive car)
    Look up DDM lighting for the e34
    Mar 2009
    Sydney
    Hi BigKriss.
    Sorry - I should have mentioned that I already have the four HID units and globes.
    Taken back off the Merc when I sold it.
    They've been sitting on the shelf for quite a while and I thought I might put them on the E34.
    ss2115.
    I use a relay setup... which engage the resistor circuit only when headlight is off so it never get hot.
    I suggest you hook up the HID and see if there is a low beam warning... alot of the modern one has a circuit in there that does the same trick as the resistor relay setup I have.
    I installed my HID in 2001
    Okay then I dont know how to help.
    I installed my HID conversion kit 3 years ago, working fine. Cheapo set from China.
  1. OBC retrofit instructions
    Last Post: 03-17-2010, 05:50 PM
  2. ABS retrofit (I haven't got ABS!)
    By E34-520iSE in forum 5 Series BMW
    Last Post: 09-22-2006, 01:25 PM
  3. OBC Retrofit????
    By schematic in forum 5 Series BMW
    Last Post: 03-20-2006, 03:14 PM
  4. OBV IV retrofit
    By iainand in forum 5 Series BMW
    Last Post: 03-19-2006, 01:21 PM
  5. Help !! OBC retrofit......
    By Mewsy in forum 5 Series BMW
    Last Post: 01-05-2005, 10:39 PM
