Results 1 to 10 of 12
Thread: She clicked over 200K the other day....
    Default She clicked over 200K the other day....
    Miles that is. Indicated. I know she has more.
    Juuuust a few new parts in the 130K or so that I've had her.
    - couple engine swaps and a new motor
    - couple tranny's
    - diffy swap
    - a few drivelines
    - 2 sets of thrust arm bushings
    - couple sets of dogbones
    - one front end rebuild
    - a radiator and coolant tank
    - who knows how many sets of tires
    - one headliner swap
    ...and a stack BMA receipts about 2 inches thick.
    Stiiiiilllll going.
    Bellevue WA
    86 Porsche 951 - Track Toy
    I hear you on the BMA receipts. It's not until you pick up the folder and start leafing through that the memories come pouring back. I still had all the docs from the original owner and from Derek too... I was jut sure the Smithsonian would be knocking at my door...
    Robin
    72 Chevy K10
    01 E39 M5
    Hey fellas, been incommunicado but mine has 240k clicks and still roars like a lion. I am still amazed at what a great car it is. My son drives it from time to time and prefers this car over the much newer and sportier GTI he owns. There is (was) a member who had 400k a couple years ago on his. That is incredible!
    All I need to do now is change the fuel hoses near the fuel filter. I get a sporadic leak from that area but I still can't locate where it is coming from. I've rebuilt the front end (timing chain, sprockets, tensioner and more,) rebuilt the head, changed oil pump, replaced front struts, numerous thrust and control arm swaps, rear subframe mounts and list goes on but for some reason this blitz doesn't compare to your engine and tranny swaps. I'm humbled (on my knees bowing...)
    Actually, need to get back to looking for the EKT (is it real OEM?) to get part numbers for these fuel hoses.
    Jan 2005
    Melbourne Australia
    Default 400+
    i have a 94 540 with 418,000 on the clock, still original engine, trans, diff..
    still running well but have upgrades to an '01 E39 540 sport. some different, very nice..
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    Hey Hector...we've both been scarce around here.
    Good to see yours is still running. My little track habit (before I retired her from that) contributed a lot of wear. A 3800lb car just doesn't like that (ab)use.
    Bellevue WA
    Lexington, Kentucky
    I am at 190 K with same engine and auto trany. All is fine. on the third radtiator and, I think, third water pump, replace thrust arms, front/rear struts/shocks. 2 sets of tires and have my winter tires on second set of stock basketweave wheels.
    Needs some suspension/steering work, driver's seat cover replaced (i have another one), and a few other minor things. Will keep driving it!!
    Also a big stack a receipts from BMA AND my local indy. Only one from the dealer's shop and a few from their parts dept.
    Dec 2006
    432,000 km's on my 91 525.
    Swwwwwweeeeeet, you guys!!!
    Yeah Russell, that reminds me I also have a steering wheel issue. Hear a clicking noise when turning right or left. I've been driving like this for over year and the problem hasn't gotten worse but the auto specialist thinks it is coming from the steering box. A while back Jeff (Regal) suggested it might be the slip ring. Good hearing from you Jeff.
    It will be a while before I join the 400-mile club. Power on fellas! Hey Robin, your absence will be felt and your contributions missed but I get the feeling you will be hanging around for a bit longer.
    Lexington, Kentucky
    Quote Originally Posted by Hector View Post
    Correct, my steering wheel also makes the clicking noise-only in winter. My mechanic told me it was the airbag? slip ring which must be replaced to eliminate the problem. Mine has done it for about 4+ years/
    If its a single click when you turn it in each direction the odds are that its the big nut under the dash on the steering shaft. Remove the lower dash panel and you can get a big crescent wrench on it. While holding it , turn the key to on and turn the steering wheel clockwise until its tight.
  1. Hitting 200k
    By rickm in forum 5 Series BMW
    Last Post: 01-27-2010, 09:39 AM
  2. hit 200k
    By skr in forum 5 Series BMW
    Last Post: 02-01-2007, 07:36 AM
  3. 540 V8 200k+ service
    By choccibicci in forum 5 Series BMW
    Last Post: 10-10-2006, 08:21 AM
  4. Happy 200k kms...
    By Nick.Hay in forum 5 Series BMW
    Last Post: 10-23-2005, 07:32 PM
  5. Turned 200K today-
    By wool in forum 5 Series BMW
    Last Post: 02-24-2004, 09:40 AM
