Results 1 to 10 of 18
Thread: Over steer on right turns
    Default Over steer on right turns
    Over steer on right turns after 55mph. Had a rear tire repaired and figured a pressure issue, nothing big but corrected a couple ponds of air. No unusual tire wear or strange noises either. I have not got it in the air yet but does anyone have a clue?
    My guess is the dog bones but not sure what they even do back there. I replaced them a year or 2 ago with FCP (****ing crappy parts) and they looked like **** in weeks, this is why I think they are suspect. Shocks seem fine as do the sway bars and links but... have not phisically looked at them yet.
    Any clues greatly appreciated!!
    TIA
    Most likely is the rear pitman arm problem. Same deal over here... I got to swap them out with Lemforders asap.
    Pitman arm = dogbones?
    Makes brutal sense to me.
    Yep on dogbone.
    There is one other possibility... bad shock absorber... when rear shock absorber go bad, upon making a right turn on wet or icy road, the rear end will slide out... oversteering.
    Bounce test for shock absorber doesn't tell you anything anymore on modern cars. You have to physically remove the shock absorber, remove the spring and check the action of the shock absorber shaft...
    Honolulu
    RTABs, subframe mounts, although unlikely could also be a suspect.
    I have some famous Hamburg Tech Dogbones in my 525 and they seem to be ok after three years... Cheap and easy to replace... 10 minutes with a rattle gun.
    Quote Originally Posted by Blitzkrieg Bob View Post
    K cool, as soon as I sell some stuff Ill try the new dog-bones, That FCP is serious garbage, C'mon 3 weeks and they spew the juice all over? I am going to start here as nothing changed extrodinarily from normal to fvcked overday.
    remember overday?
    http://www.theghoul.com/index2.html
    click memories on left
    I bought my Hamburg Tech based on you (I think)... garbage in a couple of months.
    Rockauto has Moog Rear Pitman Arm for $30.79 each... cool deal.
    Honolulu
    Not on me.... I would have told that they are crap, and wouldn,t last... I only used them because they were silly cheap ($30 for both) and an easy part to replace.
    I meant that someone on the forum mentioned about being okay.. and yes it was cheap... but not good. It is possible on my car that the subframe bushing might be the reason it is no good.
  1. Slightly OT: Effect of LSD on torque steer?
    By Adnan in forum 5 Series BMW
    Last Post: 06-15-2007, 10:05 PM
  2. :: Torque Steer
    By Qube in forum 5 Series BMW
    Last Post: 01-07-2007, 02:48 PM
  3. Replies: 5
    Last Post: 09-30-2004, 04:21 PM
  4. Wife turns 30, E34 turns heads...
    By billb in forum 5 Series BMW
    Last Post: 06-14-2004, 04:28 PM
  5. OT: Anyone work on Bobcat skid steer loaders?
    By icm5er in forum 5 Series BMW
    Last Post: 04-14-2004, 10:45 PM
