Hi.
If your getting nothing at all as you say apart from a few clicks and grunts, then it's probably the bios chip because every PC starts on the bios (Basic In Out System) which then tells the system what to start and do.
I say this because the Bios does give you the start up screen - where it says what Hdd its found, to press Delete to enter the Bios and that basic first seen stuff.
The next probable is the CPU and if its gone out in a big way, its possibly holding the power supply down which is why the Bios isn't showing - ie: the equivelent to a short. Sort of like trying to start the car with absolutely everything on that could possibly be on and having nothing left to turn the starter.
Unfortunately, Bios are chips are never replaceable and CPU's in laptops are usually hard soldered to the M/Board and not in a socket (saves room & money).
Have you tried it just on battery without the power supply plugged in? It might be a faulty 240 pwr supply or the pwr section board inside the laptop.
But test the battery first to see if its fully charged. If the 240 Pwr Supply has been faulty for a little while, or the board inside the laptop that handles the different voltages and charging of the battery, the battery might be near flat and give you a false impression that the fault still exists when in fact it could be the 240 pwr supply or its internal pwr board. These usually are replaceable or repairable.
My daughters Acer had a similar problem where the external supply kept dropping out and it would run on battery intermitedly until it flattened. I was able to repair the internal board and get it all up again.
I cannot offer any further advice. Best to see the Toshiba service agent - it might be a common problem that they know how to fix and have the parts for if its not the Bios or CPU chips.
best regards.
Originally Posted by
whiskychaser
Have of course sought help on a more appropriate board, but got an answer like 'find out which part is faulty and replace it'. Very constructive. So in the hope somebody can point me in the right direction here goes:
Her Toshibaba Satellite Pro L300-21F 'just stopped working'. Of course its 18 months old so out of warranty. A friend's techie had a quick and somewhat reluctant look and pronounced that either the motherboard or CPU was dead.The power supply light and battery light come on. When you press the power switch, the power light comes on and the fan kicks up. There is a click from the CD drive but I know drives will do that when powered. The hard drive is silent and no lights appear on it. There is no message or display on the screen. I removed the battery, the memory stick, the CD and hard drives and keyboard and still nothing. Not even a beep of protest that the memory or keyboard are missing. I've looked at the board and can see no sign of overheating but I didnt really expect to. I think the guy was right. But how do you tell if its the board or CPU that is at fault? I was told the CPU should get warm but I understand the board switches it on so its like Catch 22? Yes I know it will have to go to a specialist but I love a puzzle and would like to learn something too
Any ideas and help much appreciated. And apologies for the OT thread
ss2115.
BMW 525i Touring - 1993 (current drive car).
DS23 Citroen Safari - 1974 (restoration and modifications).
Golf MkIII - 1997 (fun car and daughters learn-to-drive car)
