Results 1 to 5 of 5
Thread: E60 N52 VC Gasket???
    San Joaquin Valley CA
    Default E60 N52 VC Gasket???
    So the shop says it's $500 to replace the vc gasket and bolt gaskets, 4 hours labor plus plus, the vanos sits on top and complicates the removal of the cam cover.
    What the???
    So I check BMA, AutohausAZ and BavAuto and no gasket on any of the sites.
    (St)ealer only?
    4 hours?
    What have I got here? Anyone done this one?
    Link to my M50 engine rebuild thread
    http://www.bimmernut.com/forum/showthread.php/43339-M50-Eng-4L30E-Trans-RRR-Far-More-Than-I-Ever-Expected?highlight=93+525+paul
    Sep 2007
    Seattle, WA
    I'm seeing part #11127581215 as a dealer only part as of now. getbmwparts.com lists it for $33.26.
    Isn't it still under warranty? Can't believe a car that new would need a VC gasket already...
    Its 3.9 hours flat rate time. The gasket is available as a Victor reinz from world pac and many others. around 35.
    All of the valve cover bolts must be replaced any time this cover is removed. They are around 33.00 from worldpac also. Most shops around here would charge 350 or so
    Quote Originally Posted by 93 525 Paul View Post
    What the???
    (St)ealer only?
    4 hours?
    Default What the? Who the?
    Thanks fellas. Wow 3.9 hours huh? I guess I need a Bentley.
    Badly.
    It is dripping from the vc down the side of the head. I failed to correctly diagnose the E34 one, let it go along with a few others and came to deeply regret it. Not this time.
    Thanks for the WorldPac tip, hadn't heard of 'em.
    Seems the E60 parts are spotty (even common stuff like front brake pads) at my usual haunts.
    No, not under warranty, bought it used w/o. The units I saw with warranties were $8k to $9k more than this car.
    Paul
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Bill R. View Post
    Those are worldpac prices? Those are higher than buying the BMW branded parts from getbmwparts.com. Kinda surprising as it's usually cheaper to buy from them than it is to buy from a BMW dealer like getbmwparts.com.
  1. Oil Pan Gasket
    By yaofeng in forum 5 Series BMW
    Last Post: 06-11-2008, 10:34 AM
  2. Replies: 7
    Last Post: 07-17-2007, 09:54 AM
  3. M50 oil pan gasket
    Last Post: 06-24-2007, 08:40 PM
  4. Bad oil filter Housing gasket & Profile Gasket
    By mbogosia in forum 5 Series BMW
    Last Post: 01-17-2006, 09:33 AM
  5. 535 oil pan gasket
    By caster in forum 5 Series BMW
    Last Post: 06-14-2004, 10:39 PM
