Results 1 to 10 of 14
Thread: 530iT M60b30 rattles when hot
    Knoxville, TN
    I certainly would not discount that as a possibility... It certainly would be a helluva lot easier to fix.
    So do you fellers think that since the sound seems localized on the passenger side of the block that it would be the A/C tensioner system roller? This really does make sense when you take into account the fact that the sound was most prevalent at the front-most valve cover bolts, and none of the other VC bolts. It would also explain the "squeaky wheel" sound (kinda like the sound Sherman tank tracks make). --I am going to run with this idea--barring any earth-shattering evidence to the contrary.
    Thank you very much. It is nice to see familiar names on the ol' forum after such a long absence--really thank you! It may take me some time; but I will report my findings...
    P/N 11281731220 $36.93 autohausaz (belt looks OK)
    Please do yourself a favor... if the age of the belt is unknown... change it... if it is old... like 5 years or so, change it... if it is squealing, change that darn thing!
    I just worked on a MB serpentine system... dang belt sounded like squealing grinding water pump bearing going... nope... not water pump at all... nothing wrong with pulley either... it was the serpentine belt fraying at multiple points... 10 or more to be exact... Changed it out and dead silent.
    I remember a Chevy Impala with Corvette engine... has a ticking noise... he thought it was water pump going bad... I told him change belt first... No... he won't... pulled engine apart to change water pump... reinstall same belt... same damn ticking! Wonderful... then he changed the belt and noise gone...
    I installed Ruville on BMW... from BMA.
    Rockauto has Uro pulley for $14.80... the part 11281731220 (qty:2, same part number as AutohausAZ) is for thtensioner.... The other one 11281731838 is for the idler pulley (qty:1) It comes with 2 years warranty. I just installed Uro pulley on MB and it seems the same quality as others I have installed... and Rockauto 2 years warranty is piece of cake.
    Uro is now OE to Jaguar, VW and Audi... for what part? I have no idea...
    Rockauto also has cheap belts too... Dayco for $8 and $13.73
    Oldham, England
    +1 on changing the belt too.
    But before shelling out, why not run it for a short time without the belt to confirm the diagnosis?
    Knoxville, TN
    Well... OK.
    I think you are both right. Thanks again.
    I will run the car sans belts for a couple of minutes to see if the noise is still there. I will keep a close eye on the temp gauge whilst doing this!
    I know for a fact that the P/S serpentine needs to be changed (It has cracking on the inside). The A/C belt looks basically brand new, and what confounds me is WHY ON EARTH somebody would change out the A/C belt and not change out the worn P/S belt when it has to come off anyway to get the new A/C belt on. Will blunders never cease?
    The PS pump could use a new pulley too.
    re URO: I believe I bought a couple of Volvo 940 wagon tail light lenses and side marker lenses for my 635CSi which were URO branded. Eastern European maybe? Seemed OK quality; fit decently. The damned reverse lenses popped off after a short time on the Volvo lenses; which was the exact reason I replaced the originals (which were16 yrs old). Luckily I caught the new lenses in time, and super glued the clear bastages back on. I will look at Rock and weigh my choices after running sans belts.
    What you fellers are saying is really making sense to me. Bear with me as mo diagnostics is run, funds are appropriated, and my slide-show is prepared to present to B.&C. I have to fill out the proper forms and submit them to the CFO/B.&C. once a conclusion has been reached. Please excuse my corny sense of humor...
    Thanks again, Giff
    there are 2 different size rollers going on there, ask me how I know. Both of mine were worn yet only one was limp enough to scream for replacement. Belt replacement is a no brainer but some new ones can be problematic as my conti squeels at startup to charge the battery. Yes full voltage on a charger and no issue, don't charge and get a squeal. Car runs much better on a full charge.
    Bottom oil pump chain is within tolerance your good to go. Very surprised no bolts backed out but on an alusil they may have got that memo and used loctite.
    It's common for the main (ie top) roller near the tensioner roller to fail, but they only start to squeak. If the belt is slipping you'll get squeal, that is contamination, wear or a faulty tensioner. It's kinda worth changing the lot in one go, and keeping the parts that are still serviceable as spares jic. That way you know it will all hang together out front for a long time.
  1. crank sensor resistance M60b30
    By Ross in forum 5 Series BMW
    Last Post: 07-27-2008, 06:27 PM
  2. Rattles
    Last Post: 05-16-2008, 06:26 PM
  3. Looking for M60b30 to buy
    By MagicMike in forum 5 Series BMW
    Last Post: 04-30-2007, 10:44 AM
  4. Door Rattles
    By Ariel525i in forum 5 Series BMW
    Last Post: 11-28-2006, 08:36 AM
  5. I got the rattles
    By digitaldragon03 in forum 5 Series BMW
    Last Post: 08-20-2005, 06:47 PM
