Results 1 to 5 of 5
Thread: Center Bearing replacement
    Default Center Bearing replacement
    I'm replacing the center bearing on a 1995 530it?
    Do I have to remove the entire drive shaft or can I leave the rear half shaft in place?
    Thanks
    Wool
    Jan 2008
    Phoenix
    Quote Originally Posted by wool View Post
    Thanks
    Wool
    I dont know that you have to remove the drive shaft but I would, it just seems like it would easier to work on that way. make sure you mark the drive shaft before separating it. It was balanced the way it is so just to make sure you dont get any vibrations I would mark it so it can go back together in the exact same position.
    Johan
    Jan 2007
    Dayton Ohio
    You will have to pull the entire shaft, or at least I had to. Make sure you mark the two halves so you get them back together in the same alignment. I marked the center and both ends to include the shaft to differential and shaft to tranny. You can remove the back of the exhaust with both metal and rubber hangers and carefully lower it just enough to get the shaft out. I removed the exhaust brace on the tranny too. This give the exhaust a lot of flex but be careful you can mess up the exhaust manifold connection. Also make sure you have enough wire loose on the o2 sensor. Once you have the exhaust down you can remove the heat shield.
    Sep 2008
    Dallas texas
    The drive shaft has to come out. You have to put the driveshaft in a vise to seperate the halves. Use a large socket to press the bearing in.
    89 535I
    89 volvo 240
    78 Pontiac Trans Am, 6.6
    Default Thanks Everyone..... Wool
    i
  1. center support bearing
    By ILoveMPower in forum 5 Series BMW
    Last Post: 01-12-2007, 10:11 AM
  2. OK, so I am not getting it - Pre-load center bearing
    By Badkrma in forum 5 Series BMW
    Last Post: 08-25-2005, 03:33 PM
  3. Replies: 1
    Last Post: 03-12-2005, 06:40 PM
  4. Preloading the center bearing
    Last Post: 01-07-2005, 01:24 PM
