Results 1 to 5 of 5
Thread: M60 oil drain plug -need fix
    Default M60 oil drain plug -need fix
    The oil drain plug on my 530it seems to be stripped and I looking for solutions but first I need to clarify the plug sizing. One reliable resource calls for 22m-1.50 plug while another reliable resource calls for a 22m-1.5 plug
    If I do remove the pan for rethreading, what would you recommend for the new plug size. (the pan is steel, not alum.)
    Has anyone come across the "oversized" replacement plug?
    I'd rather repair this than replace the pan with new or used
    As always, thanks for the help.
    Wool
    East Brunswick, New Jersey
    Quote Originally Posted by wool View Post
    Wool
    I thought it is 17mm, head and shank. If you are removing the pan to rethread, you'll find out when you do. Just use the closest size tap to rethread it. Metric or std does not matter.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Apr 2008
    Illinois
    Quote Originally Posted by yaofeng View Post
    +1
    If I were you, I'd use the closest size tap.
    Just swap the pan it's a fun job If you decide to thread in situ, fillings can be spat out via flushing old oil down + out tho...
    Aug 2007
    New Zealand
    Isnt 22m-1.5 the same as 22m-1.50? The zero literally means nothing.
  1. Broken Radiator Drain Plug - 95 530
    By DaCan23 in forum 5 Series BMW
    Last Post: 02-19-2008, 03:03 AM
  2. Magnetic Oil Drain plug - who is using them?
    Last Post: 10-09-2007, 08:21 AM
  3. Drain plug dripping
    Last Post: 06-14-2007, 06:59 PM
  4. Magnetic oil drain plug?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 07-11-2005, 05:49 AM
  5. help, I can't find the radiator drain plug
    Last Post: 05-23-2004, 02:43 PM
