Results 1 to 2 of 2
Thread: exhaust gas analysis
    Default exhaust gas analysis
    Here is some info from Bosch. Gas Analysis
    Bosch Technologies Group
    Three Reasons for Gas Analysis
    * Identify engine performance and mechanical problems
    * Test the running efficiency of the engine
    * Test for exhaust emissions against state and federal standards
    Combustion Chemistry and Gas Analysis.
    * The combustion process releases the energy stored in the fuel
    * Fuels consist basically of carbon(C) and hydrogen(H) referred to as hydrocarbons (HC).
    * Under ideal conditions all of the HCs would be converted to H2O, CO2 and heat.
    * Unfortunately this complete combustion is rarely if ever achieved
    * Short burn times, continuously changing mixture ratios and air temperatures, and combustion chamber quenching produce conditions which give rise to the formation of pollutants
    Pollutants
    * Incomplete combustion produces carbon monoxide (CO)
    * Unburned fuel produces hydrocarbons (HC)
    * High combustion temperatures produce oxides of nitrogen (NOX)
    Other Exhaust Gases
    * Carbon dioxide (CO2) is a product of complete combustion. Therefore the higher the level of CO2 the more efficient the engine is running.
    * Oxygen (O2) level in the exhaust indicates the fuel-air mixture.
    High O2=lean
    Low O2=Rich
    Gas Analysis as a Diagnostic Tool
    Gas analysis
    * Is a quick and accurate way to determine the running conditions of an engine
    * By observing the 5 gas readings and understanding their relationship to each other you can diagnose the 3 major engine areas:
    Fuel delivery
    Ignition
    Engine Mechanics
    High HC Only
    Hydrocarbons are unburned fuel. This can be caused by:
    Ignition Timing (base and advance)
    Vacuum Leaks (hoses, brake booster, manifold, evap. etc.)
    Ignition (misfires, coil breakdown, etc.)
    Mechanical (low compression, bad cam, etc.)
    Catalytic Converter Failures
    High CO Only
    * Carbon Monoxide is a result of incorrect fuel/air mixtures. Causes include:
    * For Carburetors (float level, power circuit, choke circuit)
    * For Injection (injectors, pressure regulator, temp sensor, MAP/MAF sensor)
    * For Both Systems (air filter, PCV, Evap, O2 sensor, air injection
    High Nox Only
    * NOX is caused by high combustion chamber temperatures. Check:
    * EGR (valve, controls, solenoids, passages, vacuum hoses)
    * Ignition Timing ( base and advance)
    * Engine Temperature (cooling system, fan restricted exhaust, Thermostat)
    * Vacuum Leaks (hoses, booster, evap, etc)
    * Mechanical (carbon deposits, converter, etc)
    High CO and HC
    * Normally, when HC and CO are high it is the result of a CO failure driving the HC high.
    * Correct for high CO first (Excessive fuel, restricted air, Evap., etc.)
    * If HC is still high, test as high HC (ignition, timing, mechanical, etc.)
    High CO and Nox
    * These problems are normally incompatible. If they occur on the same test they will most likely occur at different points on the drive cycle
    * Correct CO failure first
    * Retest and locate NOX failure in drive cycle and correct as NOX failure only
    HC and NoX
    * High HC and NOX normally occur as the result of a lean misfire. Check for:
    * Lean run (vacuum leaks, mixture problems, fuel delivery, etc.)
    * Mechanical (oil burning can cause high combustion chamber temperatures)
    CO, HC and NOX
    * This is a complete breakdown of the emission systems or multiple failures. Check:
    * Catalytic Converter (missing, damaged)
    * PCM (closed loop, wiring, etc.)
    * Drive cycle ( if failures occur at different points diagnose each failure separately)
    Great info!
  1. gas analysis - failing inspection?
    Last Post: 06-13-2006, 10:27 PM
  2. oil analysis, where?
    By nariusb in forum 5 Series BMW
    Last Post: 02-14-2006, 04:28 PM
  3. spark plug firing end analysis
    Last Post: 12-06-2005, 06:40 AM
  4. Oil Analysis concerns 95 525i
    Last Post: 04-29-2005, 02:53 PM
  5. Understanding a Blackstone oil analysis
    Last Post: 01-11-2005, 06:23 AM
