Results 1 to 2 of 2
Thread: Trans Code
    Default Trans Code
    Hi, I've replaced the engine and body harness on my 94 530i and now I'm getting the a Trans code and I'm stuck in limp mode.
    Transmission fault code 30 solenoid valve 1
    Fault code 33 solenoid valve 2
    Fault code 32 solenoid valve 3
    Fault code 31 solenoid valve 4
    Fault code 2 p/n shift lock
    Any suggestions would be appreciated, thanks Paul
    Oldham, England
    Have I seen this post before? Anyway, as you have got 4 valves and the shift lock showing a fault I'd suggest there may be a wiring issue. Did the new harness come out of the same year/month model? Did this include the wiring down to the tranny itself?
    You can check the wiring at the EGS socket (where the pins are numbered) and compare it to Bentleys diagram.
  1. '93 525iT getting trans program now, throwing TPS code
    By bimmerd00d in forum 5 Series BMW
    Last Post: 11-21-2010, 12:22 PM
  2. Intermittant TRANS PROGRAM code
    By semiretired in forum 5 Series BMW
    Last Post: 02-19-2007, 09:06 PM
  3. Trans Code "100"...code of death? '94 525i
    By rizal in forum 5 Series BMW
    Last Post: 10-04-2006, 06:56 PM
  4. Trans-program code no panic-Not yet!
    Last Post: 11-25-2005, 01:03 PM
  5. '94 530iT won't move - Trans code?
    By buckaroody in forum 5 Series BMW
    Last Post: 10-09-2005, 09:39 PM
