where do the 10watt bulbs go? Tail or brake? Id guess the tail but that's all it is... guessing.
PS did I ever mention Depo sucks?
If not Depo sucks balls.
as you are from the press, you probably can read
Owners manuals tells you all.....
http://luuk.xs4all.nl/bmwboeken/bmwe.../pg76.jpg.html
http://luuk.xs4all.nl/bmwboeken/bmwe.../pg77.jpg.html
http://luuk.xs4all.nl/bmwboeken/bmwe.../pg75.jpg.html
but 10W is interior light, rear lights 5 and 21W
http://luuk.xs4all.nl/bmwboeken/bmwe34manual/
10 watt goes for Tail light.
OEM shows both 21 and 10 watt, tried switching things around and the 10W goes in the tail. 21 is bright for the tail light.
Oh Depo sucks!
First day when I went to install them it busted the main connector due to shitty fit. Have light issues every once in a while that takes weeks to get working, then sometimes good for up to a whole month before another lights out. Doesn't burn them they just lose connection. Have butchered the depo and stock sockets to the point they are almost working all the time.
