As you have a 530 auto I'm guessing you have the A5S 310z. If so, did you check the resistances of said items at the EGS socket? Save you looking them up:
A5S 310Z Valve Body Resistance Nominal Values:
Resistances @ 20°C
Output Speed Sensor = 325Ω - +/- 40Ω
Input Speed Sensor = 325Ω - +/- 40Ω
NTC Sensor:
820Ω @ 0°C
962Ω @ 20°C
1118Ω @ 40°C
1289Ω @ 60°C
EDS1 = 5.9Ω - +/- 5Ω
MV1 = 28Ω
MV2 = 28Ω
MV3 = 28Ω
MV4 = 28Ω
MV5 = 28Ω
MV6 = 28Ω
Above MV Solenoid resistance values may vary up to 2Ω, dependant on
temperatures!
You will see the pinout in Bentleys though for mine the speed sensor wiring is wrong
