Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Fitting aftermarket gauges...
    Mar 2007
    Liverpool UK
    Quote Originally Posted by whiskychaser View Post
    3 pages of wiring diagrams for your motor here:
    http://www.captainjaguarscathouse.co...%20Diagram.pdf
    If you dont find what you want there at least it will tell you which wires NOT to cut into
    Looks a proper job though John. You tried it out yet?
    Brilliant thanks! I'm going to have a look now!!
    Yeah I had it on briefly last night and it was pretty cool! The engine at idle (cold) was reading 22in/hg which is pretty good from what I've read Can you remember what the 535 was reading when we measured it at yours that time?! (I remember it was pretty good too!)... Going to take it out today (whilst hooked up the 9v battery!) and see how it reads - I've got it hooked up between the FPR and the intake manifold... I read somewhere that's not the best place - What you think?
    How was the holiday anyway?!
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Oldham, England
    This might be worth a look:
    http://moodle.student.cnwl.ac.uk/moo.../vacgauge.html
    22inHG is pretty good. IIRC mine was 18 and the 535 certainly wasnt any lower than that. It changes above sea level but bearing in mind where you live I dont think you have to factor that in
    Mar 2007
    Liverpool UK
    Haha funny you mention that actually - I did some research and apparently the highest place in Liverpool is 230ft above sea level so should be fairly reasonable The gauge is getting changed as it wasn't quite calibrated correctly.
    Oldham, England
    Quote Originally Posted by e34.535i.sport View Post
    230ft above sea level? Must be the top of the Radio City tower You havent had the back of the gauge to 'calibrate' it have you?
    Reading, UK
    Radio City? Does Kev Seed still work the morning shift there?
    That guy reminds me of my childhood, used to work at Rock FM instead!
    Jun 2005
    Cheshire, UK
    The orange wire may be used to dim the display to the same level as the dash lights when they are on.
    You may not be seeing the needle settle at 0 as you are using a 9v battery to power it, rather than the 12v that the car supplies?
    1997 e39 523SEi touring.
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Omega View Post
    Hmmmm good thought. I'll let you know if this i the case when I get the replacement.
  1. Aftermarket gauges and senders
    By beetos in forum 5 Series BMW
    Last Post: 08-12-2006, 07:47 PM
  2. Retrofitting M5 gauges into 525?
    By granit_silber in forum 5 Series BMW
    Last Post: 12-17-2005, 04:46 PM
  3. M5 Gauges
    By Nick.Hay in forum 5 Series BMW
    Last Post: 10-30-2005, 02:50 AM
  4. gauges again!
    By ukm5 in forum 5 Series BMW
    Last Post: 05-11-2005, 08:57 AM
  5. Additional gauges...anyone?
    By CheapCheap1 in forum 5 Series BMW
    Last Post: 05-06-2005, 07:38 PM
