89... R12 system... I believe 70PSI... and if R134, then 45PSI. Some please correct me if I am wrong. All you need to know is the low side. No point for high side unless something is wrong with your system.
Does anyone know the correct low side and high side pressure for a 1989 525I at 80 degrees F when the system is running?
For r12 at 80F and 20% relative humidity its
low side is 31
High side is 192 psi
80f 30% relative humidity
low side is 35
high side is 203
40% relative humidity
low side is 40
high side is 216
50% relative humidity
low side is 43
high side is 223
60%
low side is 49
high side is 230
70%
low side is 50
high side is 257
80%
low side is 53
high side is 263
90%
low side is 55
high side is 286
Originally Posted by Unregistered
