Results 1 to 5 of 5
Thread: Volume air flow sensor may be dead
    Jan 2007
    Dayton Ohio
    Default Volume air flow sensor may be dead
    Today I tested the Volume air flow sensor Bentleys says to check pin 3 for around 5 volts I got 4.97...thats good . But when I test between pin 2 and 3 for a smooth resistance I got nada . Nothing no change. Can the M30 run with this not working? I understand the DME receives a resistance signal from the Volume air flow sensor and modifies the fuel flow based on the air flow. Is there a way of rebuilding this sensor?
    Sep 2007
    Seattle, WA
    Don't think you can rebuild your AFM. I wouldn't rebuild it anyways.
    I'd go with this if I had a bad AFM.
    http://www.millerperformancecars.com...&category_id=6
    Jan 2007
    Dayton Ohio
    Wow how about that war chip looks interesting. Problem is I don't have $500 laying around to put into the 5 right now. Looks like I will be driving her for a while with burp in the acceleration
    Sep 2007
    Seattle, WA
    WAR chip is only useful if you want a custom tune for your car. Want to try tuning your car yourself. Or want to have different tunes for different occasions.
    No need to go all out with the WAR + MAF combo. The MAF kit comes with a tune for your car. It's a little over $300 to get just the MAF kit (not bad considering just a new MAF for my M-Sport is that price on average).
    I'm not sure how running a bad AFM works. For bad MAF's you'll get a rough idle, bad gas mileage, and eventually I think it won't run. But the AFM is a mechanical unit while the MAF is not. And I don't know if the flap in the AFM will still open when it goes bad, or if it just misreads and has slow response when it goes bad.
  1. Air Flow Sensor Troubleshooting on the M30
    By Hector in forum 5 Series BMW
    Last Post: 07-02-2008, 07:54 AM
  2. 1994 Bmw 530i Mass Air Flow Sensor
    By Green Bimmer in forum 5 Series BMW
    Last Post: 06-05-2007, 08:43 PM
  3. Air flow sensor interchangable?
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-07-2007, 10:14 PM
  4. Air flow sensor checking
    By jj7 in forum 5 Series BMW
    Last Post: 04-03-2005, 04:29 PM
  5. volume pot for stereo???
    By FD'93-525iT in forum 5 Series BMW
    Last Post: 08-14-2004, 11:35 PM
