Results 1 to 3 of 3
Thread: rubber or brass caliper guides.. Which is best?
    Jan 2007
    Dayton Ohio
    Default rubber or brass caliper guides.. Which is best?
    Trying to decide whether I need to replace the caliper pin guides with the oem rubber or upgrade to the brass guides? Has anyone had the brass guides in for a while? If so how did they work out?
    Sep 2007
    Michigan
    I have the brass ones and they work great. probably 65,000 miles on them. I'm getting ready to do the brakes soon and they will get a good looking over from close range.
    i have the brass ones also for the rear only, since the front are a fixed caliper. I think they are good, but there is no covering for the grease (as the pin is exposed to the environment) so I clean and regrease them every oil change.
  1. SOT: Brass fittings in milimeters?
    By wjbell in forum 5 Series BMW
    Last Post: 01-16-2008, 10:01 AM
  2. i need guides, can't find any online.
    By sirius_GTO in forum 5 Series BMW
    Last Post: 03-25-2007, 04:53 AM
  3. How to install valve guides?
    Last Post: 02-16-2007, 03:01 PM
  4. Brass brake bushings?
    Last Post: 05-21-2006, 07:36 PM
  5. Replies: 1
    Last Post: 08-13-2004, 09:09 PM
