no worry, even the 1986 E32 750 already has EML, never had problem with that so far.
Does the 95 525i with the M50-TU and ASC+T have EML or "drive by wire" sytsem? I hear the earlier 535i does.
Just wondering as I do not want my car to go "Toyota" on me from electronic interference.
that is easy to check
http://bmwfans.info/parts/catalog/E3...ration_system/
the answer is NO. ASC+T has a bowden cable. Already the E32 740 which came out earlier had again bowden cable. Only 735 and 750 had EML.
Thanks, I appreciate the link.
You actually have a greater probability of having an unintended acceleration in your 525i than someone might in their toyota, as there was an issue with cables falling out of the throttle body. I had my cruise control cable fall out of my 525i and had a minor event. Luckily it was at stop and go speeds, and I was able to hold the car with the brake and pull off, wherein I pulled the cable off and hung it against the manifold with a zip tie. I think that don gale sold some clips that would keep your throttle cables from falling out.
maybe I order also some for my new E36 M3 02/1998, but still have to get more experience with the M3, all new to me.
That is the U.S. version M3, not EURO.
