Center support
Long story short. My 89 535I, the ujoint had locked up, and basically destroyed the center support bearing, causing a loud vibration. I pulled out the drive shaft, replaced it with what appeard to be a rebuilt unit , due to the u joints have clips on them and moved really good. The center support bearing looked new also. Took the car around the block after, could hear a loud ticking sound as the car would roll, then get progressivly louder . It went away after a bit, then came back when I went over a bump in the rod. The guy I bought it from asked if I pre loaded the bearing? Is this necessary and if so How do I do so? Due to the heat sheild, I can't see whats going on
89 535I
89 volvo 240
78 Pontiac Trans Am, 6.6
